thanks again mate, am gonna have a rest from it now!!! no point getting stressed over a few channels is there. have a good un mark...
you may well be right.If the SV4 has a weaker less sensitive tuner than the SV3 which is quite possible then it would explain a few things.by the way the latest firmware is 1.12 but i'm not sure it'll make any difference to your issues.Others have in the past reflashed there boxes and got results when this sort of thing has happened and i've also known reset after reset has resolved things.Might be worth a go
Hi all, i have just rescanned mine SV3 and lost nearly 100 channels also trying to solve my rebooting issue with error code LD80
hi wondering if anyone can help . i have eurovox max in notts area and lost all channels . all codes were set to zeros this morn so updated them with keymaster v1.2 , still no channels and "service unknown message" which is new as usually says "code being updated" .
so did auto scan of channels , still same results . currently doing power scan .
anyone have any better ideas as really want to watch liverpool this eve
cheers guys
gabber
If your lucky you might be able to reflash the box with the correct firmware,unlucky and you'll need to jtag the box to get it back to life.8882 is a common fault code on the SV4.this post may help a little
jtag a starview 4 box
hey everyone, have just managed to get sv4 super usb back working. WITH ALL CHANNELS. I was using old firm ware 1.07 which is why i couldnt get all channels. Just flashed with 1.12 and all is back on again even with new EPG. Yippee, for now anyway. Hope this helsp fellow sv4 folk who are having same probs!!!
My sv3 is working fine again also..
Goodluck...
pleased your sorted m8.sometimes with these boxes its just trial and error and repetition but then it all falls into place.frustrating but you normally get there in the end
yeah, many thanks for your help Mark. would not have done it without you... Lets see how long it lasts for this time???
At least i can watch your lads get beat tonite!! ;*))
See ya matey.
Tried normal scanning and only got 12 random channels , eventually got them all back , For the starview boxs , do a factory restore , go to advanced scan change start frequency to 218000 and end to 750000 now set your area frequency (6887 notts) then scan , all the channels should now come back ok , turn emu back on when finished.
hopefully this might help some who cannot get all channels back....
im trying to flash my SV3 but keep getting flash update fail can someone help?
im on windows vista if that makes any difference
Ok ... Ive updated to 1.12 all working (I think) except for SS1.
When I go into the channel edit and delete it it deletes but then still nothing no SS1 picture
Just done a factory reset and all channels are back on.
Make sure you put the emu back on!
