im in notts all my channels had gone off bout the same time but ive got an eurovox did a scan and got em all back, keep checking your post some 1 with a starview will get back to u to shed a bit of light on your problem
Hi guys
Was watchin me telly in bed and all channels went off at1.30am Wednesday Today 10th February.
I rescanned and it only found the channels on ref number 3000 then all different channels have a number like TV2103 TV2104 TV1102 ETC No channel identification now.
any one found the same problem???
Mike in Nottm...
Got up this morning only to see all the channels on the blue line across the bottom but blank screens .... did a re scan but nothing
Star view 4 box !!
Same for me, woke up to find nowt on both sv 3 and 5 boxes. Have rescanned both and most channels are back! Struggling to find sly sp**** 1 though!!! Any thoughts from anyone?
I have all the channels coming up on the blue bar at the bottom but nothing comes up on the screen.
You think a re install might help ?
it would appear that the east midlands all took a wack last night.my kryptview and sv both went about 1.30 am(Lincs)Just did a factory reset on both and all back up.I f you factory reset the SVs dont forget keycode/emu and the default key.
have just checked my subbed box and its now showing 3.7 software for the first time,so things are moving apace.
Ok .... I did a Factory Reset, then in menu press 1570 turn 'ON' the key. Do a re scan, then you should have all your channels back !! (I did )
Hope that helps
what does using default do? have rescanned and emu on, but havent done default? when i do it normally says updating but no channels?
thanks mate, still cant get ss1, for some reason also i am gettin espn on sv3 but not on sv5 in different room? any ideas on that one please?
hi every thing working fine, just rescan and you will everything back,
ok will try that, thanks.
Lost all channels this morning (Notts area). Just done a full reset and rescan and now have all channels back as before on my starview1. The only other thing I did was to plug in my Virgin box first to check that the problem wasn't theirs. It took 10mins to update, everything was ok, unplugged it and plugged in straview. Rumours are Virgin have done some mods in Notts area last night, but it's definately not N3.
I have a digivox, all channels gone this morning in nottingham area. I turned off the box, did a factory reset, turned my EMU key on and then did an automatic scan. It only picked up a view channels though. I waited 5 mins, did another factory reset, turned the EMU key on and did another scan and now they are all back. Phew. Don't like the look of this N3 stuff though, may need to look into that
