Results 1 to 14 of 14
    Default Touran 2011. Instrument Cluster update
    Hi friends.
    Have Touran 2011. with cluster:
    1T0920881a hw 05, sw 0206
    Is it possible to update software of it?
    I have searched .sgo but there is no official update for this cluster.
    I’ve heard that is possible to update to 0505 but then need to mod eeprom content too.
    *i need to update cluster to get “drive data” inf on retrofited MIB2 navigation*
    Can you help with this?
    Thnx in advance…
    Oct 2014
    Netherlands
    That hardware can be upgraded to SW05xx as highest version.
    You can use any such SW05xx FRF update.
    Indeed afterwards write a suitable and matching SW05xx eeprom (with your immo inserted), and all will be fine.
    Rgs H2Deetoo
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    jackie86 (7th November, 2021)
    Quote Originally Posted by H2Deetoo View Post
    Rgs H2Deetoo
    Thank you for reply..
    can i use .frf from this cluster?
    Tiguan:
    Oct 2014
    Netherlands
    As I've said any colour cluster FRF to SW05xx is suitable, so you can use this one:
    FL_5N0920883__0506_S
    Please read and post here your original current unmodified cluster.
    i have backed up cluster eeprom and immo data readed by OBD by VVDI2
    do you have suitable eeprom for this ?
    Oct 2014
    Netherlands
    Here is your new eeprom which you must write after flashing to SW0506 is completed.
    Rgs H2Deetoo
    Rgs H2Deetoo
    Vauu, thank you man i will post result just to catch time and try this.
    Tell me one more thing, is there any chance to back up firmware of my cluster, just in case of uknwanted scenario.. wich tool can be used?
  10. #9
    Oct 2014
    Netherlands
    Reading flash is possible with some tools but writing requires a special tool for the NEC.
    It's easier to reflash again with FRF to a lower version if you need to, for example using this FRF:
    FL_5K0920880__0209_S
    Also an SW04xx version would be possible.
  11. The Following User Says Thank You to H2Deetoo For This Useful Post:
  12. #10
    Rgs H2Deetoo
    Thank you friend.
    This eeprom that you preperad for me have different p/n from 5n0920883 that i use for
    Update.. that is ok, not gonna be problem?
    ( maybe stupid question but i am a little afraid )
  13. #11
    Oct 2014
    Netherlands
    I used an original Touran SW05xx eeprom and copied your immo data.
    This will give the best result for your cluster.
    So flash it to SW0506 and then write my eeprom and you are good to go.
  14. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    jackie86 (7th November, 2021), PremierD (10th November, 2021)
  15. #12
    big man!
  16. #13
    Friend, once again, thank you for helping.
    All went fine, i have done update cluster, write eeprom that you have prepared and BINGO!
  17. #14
    Oct 2014
    Netherlands
    Very nice
