Nano help
Results 1 to 5 of 5
Thread: Nano help
    Jun 2008
    Default Nano help
    Trying to access config.txt to edit on RPi 2 using Nano 5.5 via ssh for first time. I can't bring up lines or execute commands as the ~# is not there after initial programme login. Any ideas?
    toyota123's Avatar
    Sep 2019
    make sure you are Root...
  3. The Following User Says Thank You to toyota123 For This Useful Post:
    mikk (19th December, 2021)
    Jun 2008
    I think root access is default but will check.
    Newbie Cheeky3's Avatar
    Feb 2022
    Please note that there is a difference between root and admin.
    If I have understood your question correctly, you'd like to execute a command you need root permissions for, am I right?
    Alternatively to being a root user, you can use the 'sudo' command.
    Hope that helps.
  6. The Following User Says Thank You to Cheeky3 For This Useful Post:
    mikk (19th February, 2022)
  7. #5
    Jun 2008
    With this flavour root is default, but thanks.
