Trying to access config.txt to edit on RPi 2 using Nano 5.5 via ssh for first time. I can't bring up lines or execute commands as the ~# is not there after initial programme login. Any ideas?
make sure you are Root...
mikk (19th December, 2021)
I think root access is default but will check.
Please note that there is a difference between root and admin.
If I have understood your question correctly, you'd like to execute a command you need root permissions for, am I right?
Alternatively to being a root user, you can use the 'sudo' command.
Hope that helps.
mikk (19th February, 2022)
With this flavour root is default, but thanks.
