Hi. New clusters need wake up signal, sent by can bus.
Hi guys, I got the salvage instrument cluster 3G0 920 320B (it's from the passat B8)
I want to see if the screen works fine. I managed to find little bit of pinout, but after supplying +12V and GND, the screen remains black.
I tried to connect diagnostic VCDS 12.12: Can High; Can Low; +12V and GND, but when trying to make diag with VCDS I only see slight current increase, but screen still remains blank.
Maybe there are some pin on this cluster that activates the screen (car unlocked, door open or etc?). I don't want to got through all pins testing +12V - don't want to short anything.
Cluster have single 18 pin connector.
1 +12 V
4
5
6
7
8 immo coil
9 immo coil
10 gnd
11 Fuel gauge sender For models with no all-wheel drive varza potenciko ---<<<
12 Fuel gauge sender 2 For models with all-wheel drive
13 Fuel gauge sender 2 For models with all-wheel drive
14 Fuel sender varza ---<<<
15 Fuel sender varza ---<<<
16 Control unit 1 for information electronics
17 can bus low
18 can bus high
Hi, I got some information, that the cluster may need signal coming from the 5F module, which is information electronics unit. So I guess basically without the car it will be impossible to start?
Hi, search for solution in dashboard thread (Power up collection), some tools have option -send wake up message to cluster on table , arduino can send too, if you find what data must be sent.
you can use Iscancar MM-00t to simulate BCM, GW, 5F , ECU etc ... also help to wake up cluster
Thanks guys, I will try to do it on my free time and keep you updated if I will succeed.
