Results 1 to 10 of 10
    Oct 2016
    Default DPF message full problem TOYOTA RAV4 2015
    Hi everyone
    Does anyone have a solution for the message in the instrument cluster "DPF FULL see user manual" Toyota RAV4 2.0D year 2015 ecu Denso 275900-5001 / 89661-42J40
    The FAP / Catalyst values were reset with different diagnostic equipment but the message does not go away. We also tested with the DPF OFF solution. The engine control unit does not register an error, but the message on the instrument cluster continues.
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Post your stock file here.
    Oct 2016
    Quote Originally Posted by Inquizit0r View Post
    Hello
    i just uploaded the bdm flash file
    reproteq's Avatar
    en algún lugar de España
    this forum is for english speak aunque seamos españoles man
    this issue of rav4 I had it too and there was no way to fix it
    Oct 2016
    Quote Originally Posted by reproteq View Post
    Thanks for the notice mate.
    You are right that you have to write in English, but I am not Spanish
    Sep 2021
    SAUDI ARABIA
    DPF OK..............................
    Newbie gigaby's Avatar
    can you send pass,please
    alonedark's Avatar
    Feb 2017
    i can do no problem
    Luigi84's Avatar
    Dec 2022
    Italy
    you have to do a forced regeneration before loading the dpf off solution
    jurebv's Avatar
    Dec 2017
    Croatia
    its possible to make a reset by file , so just write and done
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  11. The Following User Says Thank You to jurebv For This Useful Post:
    Brayn (26th December, 2022)
