Results 1 to 3 of 3
    Nov 2021
    Default Cluster immo clone
    Hello guys,
    want to ask you. is it possible to clone eeprom from one cluster to another? They are same, just one has small infotainment system in the left, and the second has full FIS/MFA. The codes are same, just one number is different, number of infotainment system model.
    Since my vcds cant change cluster vin (adapt), i want to try to clone it. Someone said that its possible to put eeprom from old cluster to a new one, is it possible also?
    The car is octavia mk1 2003 facelift, both clusters are immo 3
    Thanks!
    rafal's Avatar
    UK - PL
    inside 93c86........... read both for pin then adapt by vcds
    http://wiki.ross-tech.com/wiki/index...ument_Cluster)
    need help
    now my goal is to buy xp-005
    who will help?
    kiszka's Avatar
    Quote Originally Posted by Malakasos789 View Post
    Hello guys,
    Thanks!
    it is impossible to translate eeprom
    provide the files, then I will transfer the eeprom data
