Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    Mar 2018
    UK
    The car started
    I programmed the key with the ISN from engine ECU - And made the synhro and the car started
    I remember that Autohex adverted that can read ISN from all ECUs without open the ECU but looks like this isn't true
  2. The Following User Says Thank You to Manta1600 For This Useful Post:
    comizelu (13th November, 2021)
  3. #32
    Apr 2016
    uk
    Quote Originally Posted by ASCM View Post
    Autohex cant make akl for this car
    Sent from my SM-A125F using Tapatalk
    So actually Autohex was the only one which succeeded AKL on this car..
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  4. #33
    Apr 2016
    uk
    Quote Originally Posted by Manta1600 View Post
    The car started
    Report this problem to support, program a key with wrong Isn.
    Also,no need to program key on bench,can be done on the car.
    Glad you sorted
  5. #34
    ASCM's Avatar
    Oct 2018
    I just programmed the key with the ISN 0000650A and will check it on the car
    How did you programmed a crypted cas with short isn on bench !!! Its interesting how short isn its crypted in cas eeprom(as i know short isn its not crypted in cas3++)
  6. #35
    Mar 2018
    UK
    With Autohex on bench is the same like on the car
    Key learning - option 4 AKL - Enter short ISN with 0000 upfront and program the key howding the key in key slot
    Its not realy bench just is not on the car
  7. #36
    ASCM's Avatar
    Oct 2018
    Did you tried to read isn of cas with autohex before trying to program key?because my vvdi2 show B689
  8. #37
    Mar 2018
    UK
    Did you tried to read isn of cas with autohex?
    Not possible to read from CAS
    Autohex showed the wrong ISN that I read with VVDI - If this was possible no need to open the ECU to program the key
  9. #38
    ASCM's Avatar
    Oct 2018
    Autohex and vvdi2 showing the same fake isn in cas,did you tried to program key by obd with vvdi 2?
  10. #39
    Mar 2018
    UK
    No I prefer to use Autohex on BMW and programmed the key with Autohex - The key not started the car as I wrote on the first post
    Maybe will work with VVDI and 64 times metod but on the next day I preferred to open the ECU instead to use this metod
  11. #40
    ASCM's Avatar
    Oct 2018
    Yes its true autohex its more preferable its oem tool not a clone tool such vvdi2
  12. #41
    p1et's Avatar
    Oct 2013
    VVDI2 is not a clone tool...
  13. #42
    droidwayne65's Avatar
    Aug 2015
    North America
    LOL! Well, this is a new one. Of which tool is VVDI2 a clone?
    <---- Coin of the Realm.
  14. #43
    ASCM's Avatar
    Oct 2018
    Cloned some function of SW and FW to abritess and zedfull
  15. #44
    Apr 2016
    Contact me if you need solution
