Nissan Leaf 2018 - Airbag ECU 0285014170 Repair - EEPROM ST95128RT
Results 1 to 12 of 12
    Sep 2021
    Default Nissan Leaf 2018 - Airbag ECU 0285014170 Repair - EEPROM ST95128RT
    Hi all forum
    Need help to repair dump from airbag ecu Nissan Leaf 2018.
    Airbag ECU Bosch - 0285014170
    98820-5SHOB
    Dump from EEPROM ST95128RT
    FYI this leaf model has 4 seatbelt with pretensioner (some models seems have only the two frontals). Rear-central seatbelt do not have pretensioner.
    Dump has been generated for cheap with the procedure described in: https://www.digital-kaos.co.uk/forums/sh...ost4226741
    Thanks a lot in advance.
    Feb 2017
    Try this dump and report
  3. The Following User Says Thank You to wiaderny39 For This Useful Post:
    ginettoginetto (14th November, 2021)
    Sep 2021
    Hi wiaderny39 I didn't test your proposal, arrived later than the test I did using dump get from this thread:
    https://mhhauto.com/Thread-Nissan-Le...eaf%2Bby%2BAST
    The dump I used get form the above thread and attached works, Not DTC and crashed light turns-off correctly.
    I documented that one of the bin available into thread https://mhhauto.com/Thread-Nissan-Le...828#pid2143828 are not working.
    The other question is, how to test it? one idea is to mount old fired ignitors to check if the ECU is looking for all, e.g. setting correclty DTC in case of malfuncion.
    No idea what is stored in the eeprom, if just crash data after a crash or something else useful to monitor available airbags.
    Any hint?
    Sep 2021
    As you can see the the dump I used seems come from a 2019 model, my 2018 is a late 2018.
    Sep 2021
    wiaderny39 hmmmm... doing a diff among your attached bin and the original one, seems yours seems better, at least change only few things of the original bin.
    I'll give a try, if it works, I would feel safer.
    Sep 2021
    Quote Originally Posted by wiaderny39 View Post
    I can confirm that you bin WORKS correctly, many thanks
    Feb 2017
    Good Im so glad
    slick_dick's Avatar
    Essex
    test it then .. smash car into something
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  10. #9
    Default Please help remove crash data
    Hi can anyone please remove crash data for the same airbag module 0285014170 988205SH0B, i have tried but unsuccessful
    Many Thanks in advance guys
  11. #10
    Anyone please ?
  12. #11
    slick_dick's Avatar
    Essex
    Quote Originally Posted by Remapking View Post
    Anyone please ?
    check your pm
  13. The Following User Says Thank You to slick_dick For This Useful Post:
    Remapking (7th December, 2022)
  14. #12
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default here is
    press thanks+reputation=pass
    raport here
    no raport no help next time!!
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
