Try this dump and report
Hi all forum
Need help to repair dump from airbag ecu Nissan Leaf 2018.
Airbag ECU Bosch - 0285014170
98820-5SHOB
Dump from EEPROM ST95128RT
FYI this leaf model has 4 seatbelt with pretensioner (some models seems have only the two frontals). Rear-central seatbelt do not have pretensioner.
Dump has been generated for cheap with the procedure described in: https://www.digital-kaos.co.uk/forums/sh...ost4226741
Thanks a lot in advance.
ginettoginetto (14th November, 2021), nelsoncaseiro (5th April, 2024)
Hi wiaderny39 I didn't test your proposal, arrived later than the test I did using dump get from this thread:
https://mhhauto.com/Thread-Nissan-Le...eaf%2Bby%2BAST
The dump I used get form the above thread and attached works, Not DTC and crashed light turns-off correctly.
I documented that one of the bin available into thread https://mhhauto.com/Thread-Nissan-Le...828#pid2143828 are not working.
The other question is, how to test it? one idea is to mount old fired ignitors to check if the ECU is looking for all, e.g. setting correclty DTC in case of malfuncion.
No idea what is stored in the eeprom, if just crash data after a crash or something else useful to monitor available airbags.
Any hint?
As you can see the the dump I used seems come from a 2019 model, my 2018 is a late 2018.
wiaderny39 hmmmm... doing a diff among your attached bin and the original one, seems yours seems better, at least change only few things of the original bin.
I'll give a try, if it works, I would feel safer.
Good Im so glad
test it then .. smash car into something
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
Hi can anyone please remove crash data for the same airbag module 0285014170 988205SH0B, i have tried but unsuccessful
Many Thanks in advance guys
Anyone please ?
Remapking (7th December, 2022)
