HEllo frends please someone help about ABS Coding , i try manual method find on this forum but no luck
Tiguan is 2009 year, 2.0 TDI 125kw engine, 4 Motion, left side steering. Here is AutoScan from VCDS .
THX in advance
Friday,12,November,2021,18:44:45:02408
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0
Data version: 20200421 DS317.0
www.Ross-Tech.com
VIN: WVGZZZ5NZ9W028115 License Plate:
Mileage: 205740km-127840mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZ9W028115 Mileage: 205740km-127840miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 016 M HW: 03L 906 022 G
Component: R4 2.0l TDI 0000SG 9979
Revision: 13H01--- Serial number: VWX7Z0H63NM11F
Coding: 0000172
Shop #: WSC 80093 222 71269
VCID: 3C4E7707AC311C35E4-8068
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 205746 km
Time Indication: 0
Date: 2000.00.00
Time: 18:18:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Torque: 219.0 Nm
Hex Value: 0xFF02
Bin. Bits: 00000010
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 L HW: 5N0 614 517 L
Component: J104 C2 450 V2 0006
Revision: --H12--- Serial number: 00000001331613
Coding: 0002356
Shop #: WSC 01324 785 00200
VCID: 37458976B8163E08CC-8062
7 Faults Found:
01324 - Control Module for All Wheel Drive (J492)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 194
Mileage: 205746 km
Time Indication: 0
Date: 2000.00.00
Time: 18:39:17
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00000010
Count: 238
Hex Value: 0x0000
01314 - Engine Control Module
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 194
Mileage: 205746 km
Time Indication: 0
Date: 2000.00.00
Time: 18:38:40
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 3.50 V
Bin. Bits: 00011111
Count: 165
Hex Value: 0x0000
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
00810 - Sensor 1/2 for Brake Pressure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7B81F1BAA87A86ECEC-802E
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008703775
Coding: 01880FA300041C0047190000140000000009FF475C40010439 0000000000
VCID: 33398162880256F4AC-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 180708 012 0203
Coding: 00038805
Shop #: WSC 01324
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__200 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPDRQTFV
Coding: 0012336
VCID: 3B41717AA83A062CEC-806E
Subsystem 1 - Serial number: 6333FTS662251968
Subsystem 2 - Serial number: 6343FTS671121968
Subsystem 3 - Serial number: 6353ETS6FQF9UVNH
Subsystem 4 - Serial number: 6363ETS64G59UVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 752 0101
Coding: 0000012
VCID: 7F8DF94E588E6E000C-802A
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 5N0 920 870 D HW: 5N0 920 870 D
Component: KOMBIINSTRUMENT VDD 2420
Revision: V0004000 Serial number: VWX7Z0H63NM11F
Coding: 0007104
Shop #: WSC 00001 001 00001
VCID: 313B9D5880085AE69C-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 100708F2002896
Coding: F9827F060002026002
VCID: 3547856CB01C22FABC-8060
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 234
Mileage: 205746 km
Time Indication: 0
Date: 2000.00.00
Time: 18:31:59
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 234
Mileage: 205746 km
Time Indication: 0
Date: 2000.00.00
Time: 18:25:07
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4B51512A688AA69C6C-801E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2420
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5N0 959 701 HW: 5N0 959 701
Component: Tuer-SG 006 1205
Coding: 0000180
VCID: 727803A5844FD0AF94-8026
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 G HW: 5N1 909 148 E
Component: J500__APA-BS KL.097 0401
Revision: 1AH01251 Serial number: 00080630291802
Coding: 0000258
VCID: 36448B69B4133803B4-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 80800A0052830C7F3F04840560084F0BE0FC00
VCID: 0309E1D2481276A42C-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5N0 959 702 HW: 5N0 959 702
Coding: 0000180
VCID: 737901A28842D6B4AC-8026
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H08 Serial number: 00000000072205
Coding: 0000057
VCID: 2E3C9B5194FB48CB74-807A
3 Faults Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 205727 km
Time Indication: 0
Freeze Frame:
Voltage: 11.40 V
Count: 43
Speed: 0.0 km/h
Hex Value: 0x12C0
Hex Value: 0x0001
Hex Value: 0x0101
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11110101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 205727 km
Time Indication: 0
Freeze Frame:
Voltage: 11.40 V
Count: 101
Speed: 0.0 km/h
Hex Value: 0x12C0
Hex Value: 0x0001
Hex Value: 0x0101
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 2
Fault Frequency: 8
Reset counter: 194
Mileage: 205746 km
Time Indication: 0
Freeze Frame:
Voltage: 11.70 V
Count: 71
Speed: 0.0 km/h
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5N0 959 703 HW: 5N0 959 703
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 748607AF8C59ACBDA4-8020
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5N0 959 704 HW: 5N0 959 704
Coding: 0000144
VCID: 758705ACB05CA2BABC-8020
End-------------------------(Elapsed Time: 02:19)--------------------------
Tempus Omnia Revelat
