    May 2021
    Default Nissan note 2 button remote
    Nissan note 2013. 2 button blade remote extra remote can't enter programming mode can anybody tell me if is manual procedures 6 on or off or diagnostics normal blade remote
    Lock and unlock with key the original works okay the additional remotes 2 tried both can't program original Nissan remote keys thanks
    Dec 2017
    Bulgaria
    proximity key or regular
    to regulare
    Early methodStep 1) Sit in drivers seat, close and lock all doors.
    Step 2) Insert key into and remove it from ignition key cylinder more than six times within 10 seconds.
    (Hazard warning lamps will then flash twice).
    NOTE:
    Withdraw key completely from ignition key cylinder each time.
    If procedure is performed too fast, system will not enter registration mode.
    Step 3) Insert key into ignition key cylinder and turn to ACC position.
    Step 4) Push any button on remote controller once. (Hazard warning lamps will then flash twice).
    At this time, the oldest ID code is erased and the new ID code is entered.
    Step 5) Do you want to enter any additional remote controller ID codes?
    A maximum of four ID codes may be entered. If more then four ID codes are entered,
    the oldest ID code will be erased.
    If you do not want to enter any additional remote controller ID codes, go to Step 9).
    Step 6) ADDITIONAL ID CODE ENTRY
    Lock all doors with LH (driver side) lock/unlock switch
    (in main power window and door lock/unlock switch).
    Step 7) Push any button twice on remote controller once, (Hazard warning lamps will then flash twice).
    Step 8) Do you want to enter any additional remote controller ID codes?
    If so, unlock doors then repeat Step 6) and Step 7).
    Step 9) When complete, open door, and check operation of remote.
    From the service manual.......
  3. The Following User Says Thank You to lamer4epz For This Useful Post:
    godfathertwo (16th November, 2021)
    May 2021
    Regular 2 button key with lock and unlock.
    Mar 2018
    UK
    I dont think that this car use separate remote with manual programming
    If is late registration on the old shape must be 7946 chip on board precoded like Micra to up 2010
    if is the new shape must be 7961
    newone's Avatar
    Oct 2016
    note e11 intergraded key like micra k12,note e12 intergraded key like micra k13,remote adapt same time with immo
  7. The Following User Says Thank You to newone For This Useful Post:
    godfathertwo (21st November, 2021)
  8. #6
    Dec 2017
    Bulgaria
    so it says in the service manual. option with and without nissan consult
    KEYFOB ID SET UP WITHOUT CONSULT
    ID codes should be erased. After all ID codes are erased, the ID codes of all remaining and/or new keyfobs
    must be re-registered.
    To erase all ID codes in memory, register one ID code (keyfob) five times. After all ID codes are erased, the
    ID codes of all remaining and/or new keyfobs must be re-registered.
    • When registering an additional keyfob, the existing ID codes in memory may or may not be erased. If five ID
    codes are stored in memory, when an additional code is registered, only the oldest code is erased. If less
    than five ID codes are stored in memory, when an additional ID code is registered, the new ID code is added
    and no ID codes are erased.
    • If you need to activate more than two additional new keyfobs, repeat the procedure “Additional ID code
    entry” for each new keyfob DLK-256, "ID Code Entry Procedure" (with CONSULT), DLK-257, "ID Code Entry
    Procedure" (without CONSULT).
    • A maximum amount of five ID codes is allowed. When more than five ID codes are entered, the oldest ID
    • Even if same ID code that is already in the memory is input, the same ID code can be entered. The code is
    counted as an additional code.
  9. The Following User Says Thank You to lamer4epz For This Useful Post:
    godfathertwo (18th November, 2021)
