it's a "roll lock" ecu, not related with keys. The mp3 ecu normally marked with "ACxx" (xx = II, 2, 5, 27..etc)
sisanovic1 (18th November, 2021)
So this is not the right modulle? There has to be an other module where the keys are stored?
I see the link will ask the customer to check if there is an other module. Thanks so far
Verzonden vanaf mijn iPhone met Tapatalk
this is steering module
ecu is on engine
Tnx guys i found the right module! Throttle module on the engine
sisanovic1 (10th December, 2021)
I have friend service has this ecu digitek ceca x2 damaged,and now check engine is on and throttle can be increased
Is any chance to disable the need of this module inside main engine ecu?
Any info?
