What Number ecu You have? What model MT 09 tracker or not. I think You have not correct ecu. Immo off/on not have anythink to diagnostic.
Hi, if there is immobilizer ON in ECU, then there might be no communication with ECU with standard diagnosis? I've got xdf with option to disable immo, but it doesn't make any difference, so I'm not sure if ECU is corrupted or maybe immo isn't turned off correctly.
If I remember correctly the immo is not a single switch on this ECU. What does the xdf change with immo on/off?
Your ecu number is correct into this model. Your bike start? I flashed few mt-09 with immoff and other tunes. Newer have problems .
Mabey your bin is incorrect. You read it Your self by AUD ? What software You use to flash? This ecu is SH7058 If You wanna I can compare it with my stock bin.
BIN file is correct.
