Results 1 to 3 of 3
    Oct 2021
    Default Steps replacing cluster eeprom question
    Hi..
    Question:
    After replacing damaged inst. cluster eeprom to my car skoda immo2 with new one after programming it with downloaded dump file from the forum of same model and type ..and writing the same pin code extracted from the ecu dump file into it.. did i still need any further steps to make it work? ...as key matching/ adaptation using VCDS (or this step only for instrument cluster swab with different dump file than the original one), .....
    Meat-Head's Avatar
    Quite pissable problem is crypto. Each eeprom data, matches mcu, only one in the world
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    Faisal kg (24th November, 2021)
    fuzz1's Avatar
    Jul 2019
    What would be the solution? Replace the whole set? Surely must be other way
