Results 1 to 5 of 5
    Jul 2019
    Default Mercedes W203 C200 2005 - no crank problem
    Hey, I've go problem with my W203 2005 - recently I changed EIS + ELS cause it failed. After changing EIS + adding emulator key turning perfectly but when its in position 3 car just not start/crank.
    I checked fuses, starter relay, battery. All seems ok. What else can cause this problem? Thanks for help
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    did you program emulator with ori els data?
    If i Helped you,use thanks and rep button to thank me back
    Jul 2019
    This emulator was working before. I think it was programmed but even universal emulator was working before. It unlocks EIS and I can turn a key, dash is working and i hear pump
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    What fault codes?maybe the issue is something else,like crank sensor
    Jul 2019
    Today i switch ignition ON and everything went nuts. Pulled SAM and it looks wet. Gonna clean it tommorow morning
