Hello, looking for help in reading Denso DEC 30 ecu which i have in Corsa C 2006 1.7 CDTI 100HP.
I have China clones i can use: Kess v2, FGTech v54, MPPS v21
So far i have found that i could use (Corsa 1.7 16V DTI Denso LRDX Hybrid CAN) in MPPS and connect it like diagram i found (attachment), but haven't tested it yet. Is it correct i will Read/Write it by this way ? .
---solution---
https://www.digital-kaos.co.uk/forum...=1#post4313944
need help
now my goal is to buy xp-005
who will help?
Of course you can, just be careful with mppsV21 ... try the fgtech v54...
Kisu1337 (27th November, 2021)
Ok had few problems but finally i have read Flash with MPPS V18.
How to make my spare ECU to be able to start the car ? i have to make it Virgin somehow ? and will it auto-adapts when 1st start?
ECU Read in attachement
You need to read Pin from spare ECU, then you can Program it by OpCom
No, you need to get Pin code from your spare ECU by reading eeprom
then with OpCom renew ECU using his Pin code
After that Immo Function and Program Ecu to Car,
perhaps you need also to program BCM, done....
This ECU is Hybrid so i can't desolder eeprom and read it with my eeprom programmer, KESS V2 EU and KTAG doesn't support this ecu.
I also have standard BMW+DCAN cable and MPPS v18.
How can i read/write eeprom ?
Any cheap solution ? Maybe CarProg ? IPROG+ or anything else i can buy?
Carprog, and less are all you need for full clone flash and eep. Opcom is optionally, just for dtc clear.
Or use carprog to get pin code from eep and reset all modules and reprogram them with opcom.
P.s. Not "less". I meant Kess.
budata (7th February, 2022)
Search again. Upwards in the list.
budata (9th February, 2022)
I have read FLASH with MPPS V18 But i still can't manage to read EEPROM of this ecu, i guess it is 93C66 but it is 16bit and CarProg has only 8bit read which aint working.
