You need to adjust the actuator, it's too tight, usually I first run a test to see how much pressure I need to open any actuator before I install it using a Guage and pressure bcoz it's so tiresome removing that thing and installing.
So I would suggest you adjust the actuator until it's has play then tight 3 threads at a time until it's snag then test to see if it ok otherwise if it's still overboosting, then you need to replace the actuator.
But I also think 10-20 percent throttle is too low and I think the map should also be considered.
I would also suggest writing back the old file to see it it's the same.
Cheers
R
