Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
"clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
WinOLS 5
IF helped! Press "Rep & Thanks"!
ASCM (21st November, 2021)
Si no te gusta ese ruido cómprate otro coche de gasolina y arreglado
WinOLS 5
redonerj (10th December, 2021)
Hello. Do you know if this valve still exist on newer 1.6 cr tdi ? I have looked on my 2 cars and it seems to be very different...
Many thanks 😉
https://www.digital-kaos.co.uk/forum...1&d=1679427837
Im one of the affected 1.6tdi cayc owner white te same issue (injector rattle noise) around 2000rpm.
Two years ago I replace all 4 injectors with the VDO ones and perform the dieselgate upgrade to 9979 sw version. Currently i made around 20k km with the new injectors.
After the deviation quantity was performed via vcds seems that the noise of the injectors were still present when the cooling temp is set around 90°. My i was thinking was an egr issue even there was no fault codes on it, so i decide to change. Nothing really changed except the vibration which gone when I stop the engine(the vacumatic valve was somehow broken).
I found out this thread where Sonda user mentioned to remove the injector return valve from the pipes since it could getting clogged and i do that. After that, the injector noise is completely gone witlut any quanity injector deviation (i will do it later).
I was courios whats inside of that return valve and i flund that nothing seems to be able to block it somehow. Inside there is a spring and a metalic ball which from my perspective it cannot be blocked.
So i think the real issue in this case is the dieselgate sw which injecting a bit too much fuel and the excess is returned and blocked by the valve causing the injectors noise.
Now im wondering if something will go wrong since this valve is a uniq valve flow direction..
Hello all, is there somewhere valve on fuel pipes on DDYA? My injectors are knocking. No idea how to fix it... Replaced all 4, learned new fuel inject...
