Results 1 to 7 of 7
    Jul 2016
    Ukraine
    Default SPRINTER W906 EDC17CP10 please remove DTC
    Friends, help to remove the DTC P149A P148C P155D P1209 P1447 after the swiftec_egr off , the original dump is in the attachment.
    Mercedes Sprinter 3.0 EDC17C10 SW1037503.Thank you.
    Baddog84's Avatar
    Sep 2012
    Germany
    nice software
    make good egr of and no dtc off need
    check your pm
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  3. The Following User Says Thank You to Baddog84 For This Useful Post:
    urametz (21st November, 2021)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    try this
    good luck
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
  6. #4
    Jul 2016
    Ukraine
    Thank you very much, friends for the quick and I think good help, I'll check and report. I will always be glad to help you in those matters where I have more experience.
    Jun 2020
    Quote Originally Posted by urametz View Post
    Here your egr dtc off.
    B. regards
    File service, Custom Remapping, stage 1 & 2 dyno tested.
    Petrol + Diesel
    Adblue dpf egr Only tested working solutions.
    Use thanks and Rep if my help was helpfull.
  8. The Following User Says Thank You to Krisfuzzy For This Useful Post:
    urametz (22nd November, 2021)
  9. #6
    Jul 2016
    Ukraine
    Report, option "Baddog84" is a swiftek egr off - the solution is not complete, the dtc map is not deleted, the "immokill" option is more correct, but it is necessary to kill the dtc P14CF00 because the car enters limp mode even when the usr plug is disconnected.
    Request to kill dtс P14CF00 in my dump
  10. #7
    Apr 2016
    Use this file.
    You can disconnect plug if you want.
    Pass PM
