Results 1 to 2 of 2
Thread: audi a3 8p
    Apr 2011
    Default audi a3 8p
    Audi a3 8p with automatic transmision not crank... In transmision selector lever is in P...Starting enable ok in transmisio. KEY good... in bcm have 75x relay error... in motor starting enabled....
    on 2 relay from central electronic and engine ecu not have gnd to relay to activated starter.
    in central electronic when start car in measuring values can input zas is on.. terminal 50 FB OFF.. TERMINAL 50 CAN OUTPUT BCM OFF..
    THX A LOT
    Nov 2021
    You can show fault code!!
