[quote=cjawahir;467931]post no.4 my m8 cj sorry forgot to say cj also knows everything about bmw,s. And he also is a master thanks again cj
http://www.digital-kaos.co.uk/forums...problem-84248/
oh man, not realized that the files are so close. just searched the whole forum. Thanks to obdmaster.
@obdmaster
Did you ever tried to read the DME-flash of your dads car with BMW-Scanner?
i dont think you can m8, you can write isn into ews using inpa or bmw scanner though m8
And you can read isn using inpa or bmw scanner from DME m8
Here is the Enforcer sw. It can be used also for other programms for activate buttons not only for Ews Editor sw.
hi, no i don?t want to bypass the i**o, but i want to find out something concerning the im*o-system. BTW, it?s possible to bypass the ews3. But, afaik it?s a lot of work and those guys who can do that are very expensive.
What i wanna do is to find out is how the VIN and ISN is encrypted in bmw-ecus. I thought i got it, but recently i got a BMS46 ECU and a DDE4-ECU where my method not worked.
I need to compare ews-dumps with dme-dumps from one car.
With BMW-Scanner you can read out the DME, already tested on a few ecus. Thats why i asked obdmaster if he ever tried to read the dme-memory.
@obdmaster
It?s not possible to read out the ISN with INPA or BMW-Scanner on cars produced later then ?98.
Do you have BMW-Scanner?
regards
If I recall it right is not possible to read ISN via BMW scanner or inpa when EWS 3.3 was implemented .EWS III (3.3) is installed in the 1998 E38 from 5/97 production, in the 1998 E39 from 9/97
production, in the E46 beginning of production, in the E52 and E53 beginning of production.
In this case you have to read the ISN straight from the DME dump using calculator
i fyou use bmw scaner 1.40 you can read isn number but the ews and engine ecu must be a matching set.
i know this as when i change engine to bigger size i read isn no with bmw scanner and the input into car ews so as to keep the same keys.
regards
mostly e46 and e39
regards
I guess those cars were pre 1999 MY, not immo 3.3cars, thats why you were able to read the code via the scanner
hi
the faster way to read EWS without removing any thing , by K line with xprogm
if you have EWS3 authorisation
you will be able to modifie EWS 3 , in the up area : tools
how to read ews by k line with xprogm
.how to connect the wire
