Results 1 to 10 of 10
Thread: Megane 2 225 RS
    Nov 2021
    Default Megane 2 225 RS
    Hello,
    I need pops and bangs and 2 lambda off.
    I tried to do it myself, but there is no suitable damos for WinOLS and drivers for ECMTitanium: /
    Can someone please help me?
    Thank you very much !
    S0nda's Avatar
    Nov 2021
    Reading....
    if no file there is no HELP
    Jun 2019
    slovakia
    publish your file
    Nov 2021
    I add file
    Jun 2019
    slovakia
    do you have any fault on the rear lambda probe at the moment or is there only a downpipe and the lambda probe is connected? personally I have a megane 2 rs and I have a downpipe rear probe connected and I have no problem with that. so I don't see the reason to turn it off S3000 he's not sensitive to that either
    Nov 2021
    I have downpipe and sometimes it shows check engine 2 lambda sensor.
    I really want to add pops&bangs (soft, not hard )
    Jun 2019
    slovakia
    S3000 MatJJJ megane 2 rs.rar try it pass pm the check will only appear if you are driving as a pensioner. it showed me once a year when I had the turbo clip loose and I was slow so as not to shoot the hose
    Nov 2021
    I studied for a few days..
    This is my effect remap for pops and bangs : Renault Megane 2 GT RS 250km Pops and Bangs Sound check ; Remap - YouTube . The shots are too strong
    i want to do make safe (and quiet, I don't want big explosions).
    I want this effect with fewer shots. Wants to have shots from 3000rpm :
    EXTREMELY LOUD DECAT MEGANE RS DRIVE - YouTube
    Could someone please advise me how to set spark advance (-2* or -7* or -15* for safe pops and not big explosion)
    Please help me
    Nov 2021
    Which option is better?
    - increase the fuel dose
    - delay ignition (-10 / 15 *)
    The 3RS has great pops and bangs, I've seen the 3RS engine map and has more fuel when it drops from rpm
    May 2017
    -10 to -15 normally works good. More reatard mostly do more crackles.
    No need to increase fuel a lot... more fuel can end bad way. A little bit fine enough. You also can play a bit with the valve o~~~~~p.
