OPEL VECTRA EDC16C9 DPF OFF AND DTC 1.9cdti
Results 1 to 3 of 3
    Nov 2021
    4
    Default OPEL VECTRA EDC16C9 DPF OFF AND DTC 1.9cdti
    OPEL VECTRA EDC16C9 DPF OFF AND DTC P1902 1.9cdti THANK YOU ADVANCE
    Aug 2020
    Birmingham,England
    89
    hi,
    you can try this
    but some times you need full BDM Read for edc16c9 ecu with ktag
    you can test and see if it works
    DPF OFF & P1902 Dtc Delete
    IF I HELPED YOU DON'T FORGET TO HIT THANKS AND REP
  3. The Following User Says Thank You to geedot187 For This Useful Post:
    Robinfull (26th November, 2021)
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    36
    Agreed, most of the time you will need full BDM read for Full EGR or DPF solution.
    I hope this helps... Easy to read with KTAG..
    THANKS + REP = PASS
