ETL or the MicroCafe clone and tmpro unfortunately just this three stuff able to read it.
If it's 8C then the very same immo data stored in the engine ecu
Sir, are you classified as human? Negative, I am a meat popsicle
davorOS (26th November, 2021)
still fighting with this one it look like immo box MCU is faulty and I can't read it
I try to code key with ECU pin and car accept code after I enter it but keys are not coded
so I try to make immo off with julie emu so I write 93c56 with 33 in all location need but emu blink every 2 sec as in manual but car not crank
anyone have any solution?
Put back the orig dump in the ecu and the immobox to the car and you can write the key data from the ECU dump to vvdi superchip.
If the immo really not working and you able to buy another immobox i can give you a dump which is matched to your ecu
thisi is new immobox file
I need to new ecu file with keys
thank you
i think you data of ECU are PIN 9213 4567
KEY1 48 1B 98 8A
KEY2 36 0C 9C 8A
than this is your new file for ImmoBox
