Results 1 to 9 of 9
    Default Rover 820 Immo off or Virgin file needed
    Hi all, i need to fix the immo in a Rover 820, immo off dump 1996-7
    Land of Rocks
    This must work. Dont forget to cut pin 13 in ecu before power on car.
    busaman's Avatar
    suffolk uk
    sorry to hijack this thread what ecu is this i need im*o off for a freelander 1998 with this ecu
    It's a MEMS 1.9. The Code is stored in the 93C46 in the bottom left corner of the picture.
    HTH
    Land of Rocks
    Quote Originally Posted by busaman View Post
    Put the same dump in 93c46. Works for all MEMS ecus.
    Meat-Head's Avatar
    Quote Originally Posted by teckie2 View Post
    HTH
    Quote Originally Posted by tachonow View Post
    De ja vous
    busaman's Avatar
    suffolk uk
    thanks meaty i did swap the chip but that must be damaged or corrupt. now i can have another go.
    Meat-Head's Avatar
    CAUTION:
    THREAD HIJACKER HAS BEEN HIJACKED
    In the dead met-rot thread, the circuit board got damaged, so soldered some THIN wires in place, did what the rapper 'Eminen' would do ('round the outside', 'round the outside' <of circuit board>) brought them to a piece of vero-board with a chip holder then stuck this with siliy-coon to the MCU processer and then skanked a chip off a H+P cat 1 car alarm.
    You still have the other ecu/chip to re-cycle and remember to cut pin 13 (THINK middle row at one end, dud)
    Jul 2019
    Whether it is possible to establish this dump on Rover 820SI.
