Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    Jan 2016
    Default Yahama Xmax 400 pincode from 24C02
    Can some one give me the pincode of this dump please ?
    If someone use Smart tool , i would like also talk about it please.
    Olivier
  2. The Following User Says Thank You to bid178678 For This Useful Post:
    saraiva79 (7th April, 2023)
  3. #2
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by bid178678 View Post
    Olivier
    This now Yahama or Yamaha ?
    Jan 2016
    ... Yamaha
    Jun 2016
    Budapest HUNGARY
    ... Yamaha
    PIN all character number ?
    i look 7byte data 3x
    4byte data 3x
    12byta 3x
    Jan 2016
    Pin hex = 34 65 21 48
    Jan 2016
    Pin code is 6 digit
    Dec 2016
    your pin is 575373 try and report please
  9. The Following 4 Users Say Thank You to keyselberti For This Useful Post:
    bid178678 (1st December, 2021), hcip (1st December, 2021), Medeonne (4th August, 2022)
  10. #8
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by keyselberti View Post
    I am sure your pin code is correct....
    Best Regards
    Quote Originally Posted by f2f2 View Post
    4byte data 3x
    12byta 3x
    6byte, need to add 1 in every character to output the pincode for Yamaha
    4bytes for Suzuki Smart pincode
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  11. The Following 3 Users Say Thank You to hcip For This Useful Post:
    bid178678 (1st December, 2021), siberian90 (5th May, 2022), sv2hqx (7th February, 2022)
  12. #9
    Jan 2016
    Thank you guys
  13. #10
    Jan 2016
    hcip could you send me your email in mp please, i would like to talk with you of pincode calcs for Yamaha
  14. #11
    Jan 2016
    Hi Keyselberty, Hello Miss Hcip,
    Could you help me this time to find the pin code on a Tmax stering lock dump ? It seams to be not the same calculation than the Xmax ?
    Firt dump with pin code known to help verify calculation hex = A1 35 1D 68 -> pincode = 641573
    Second dump with unknown pincode hex = CF 37 1F 92 -> pincode = ??????
  15. #12
    hcip's Avatar
    CF 37 1F 92 -> pincode = ?????? 841228 or 851228
    I am not sure , just give it a try
  16. The Following 5 Users Say Thank You to hcip For This Useful Post:
    bid178678 (11th December, 2021), igorr (11th December, 2021), Johnner (13th December, 2021), sv2hqx (7th February, 2022), vanos batam (15th April, 2022)
  17. #13
    Jan 2016
    Hello Hicip, you are too fast for me ,i will try the codes in 2 days
    Thank you very much for help.
    Have a good weekend.
  18. #14
    Jan 2016
    Hello Hcip ,
    CF 37 1F 92 -> pincode = 841228 is a winner !
    Great job !
    I try to calculate on my side , but no success. Any tips to help me to calculate?
  19. The Following User Says Thank You to bid178678 For This Useful Post:
  20. #15
    hcip's Avatar
    Hello Hcip ,
    Great job !
    Good, Can you share the dump File?
