i try imiev with AVDI and it was impossible to do AKL situation same with LONSDOR
I try every method and didn't work at all to do the transponder . about remote it worked ok .
Can someone confirm if Mitshubishi i-MiEV, Citroen C-zero and Peugeot iOn can be done the same way as Outlander, 4007 and C-Crosser?
They all seem to have the same PCF7941 board with Mitsubishi knife blade.
I found feedback about the Outlander that it can be done with Keydiy remote and separate PCF7936 but nothing about the i-MiEV.
So for adding a key it should work.
And for AKL there's not even an EEPROM solution?
I tried with Lexia to code a new ID46 7936 but just keeps failing, same on ZedFull.
Was able to clone using KD-X2 with a 7936 & a KD remote programmed with Lexia no problem.
Can you get plain PCF7941 chips?
autoTkey (4th December, 2021)
(as far is remember) with autel i tried adding a new orig remote key (customer had spare key) and it was a disaster. Only the new key worked the spare key is deleted and impossble to relearn. And the new key remote part not working. I had to learn with other stuff.
autoTkey (6th December, 2021)
What procedure do you use to program the remote for the C-Crosser/4007 ? Is it programmed over OBD2 or via a manual procedure ?
I always assumed that the C-Cross key has the remote programmed togeteher with the transponder since it is a PCF7941 which is integrated on all other cars as far as I know.
nope there is a separte 7936 and the remote with 7941 without transponder coil, like in the Chevy Captiva/ Opel Antara
We got the same case recently. Only first remote is memorized with Autel, no matter if it is the original or KD/XH.
Had to use Peugeot Diagbox (it was a 4007) to program both remotes.
And for the transponder - had to prepare it as ID46 for Mitsubishi and then learn with Diagbox.
recently i did a c-zero under citroen only the tp part was active and the tp learning went fine, under the mitsu i-miev menu there was remote menu and worked too. 2016 or similar
The normal mitsu remote (ASX style) working fine with separate 7936
