Results 1 to 12 of 12
    fuzz1's Avatar
    Jul 2019
    Default Modify vin number of srs unit
    What tools do you need to modify vin number in srs unit?
    Would vcds do it for vag airbag ECU?
    svenin53's Avatar
    Apr 2020
    Ukraine
    VIN set's via EEPROM, it's simply)
    But you need a right codding for you car if srs unit used from another car.
    Please dear members push the button if my work was helpfull!
    KESS 3, IProg, X-Tool, CG-100, GCPT, etc.
  3. The Following 2 Users Say Thank You to svenin53 For This Useful Post:
    duner (29th January, 2022), fuzz1 (4th December, 2021)
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Depends on a car. Ford can be done by CPT for example.
  5. The Following User Says Thank You to slavax For This Useful Post:
  6. #4
    fuzz1's Avatar
    Jul 2019
    I did for PSA cars via telecoding online though.
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by svenin53 View Post
    If i modify vin in eeprom what should be done to keep the integrity of the dump? Crc check will fail
  8. #6
    svenin53's Avatar
    Apr 2020
    Ukraine
    Need a CRC Calc)
  9. The Following User Says Thank You to svenin53 For This Useful Post:
    fuzz1 (25th January, 2022)
  10. #7
    fuzz1's Avatar
    Jul 2019
    Does UPA s have that possiblity to modify the crc? Saw that in the soft but i admit don't know how to use it
  11. #8
    Jul 2021
    new delhi, india
    Tried it and successfully done it. Many a times. Believe me
    Sent from my vivo 1723 using Tapatalk
  12. #9
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by Sandeepa View Post
    Would you mind sharing how you did it what tool you used and on what module?
  13. #10
    Jul 2021
    new delhi, india
    Hi buddy
    I have done this on modules with similar hardware but different memory files. The modules of hyundai, kia, suzuki, toyota etc are similar hardware wise but have different part numbers and versions and can be successfully swapped. Replace the d flash, p flash, d+p flash and boot files of the memory chip and the module can be used in other vehicle. I just did it 2 days back with modules of suzuki s cross 38910-64m10 and suzuki vitara brezza 38910-82p10.
    Thanks n stay safe mate
    Sandeepa
  14. The Following User Says Thank You to Sandeepa For This Useful Post:
    fuzz1 (29th January, 2022)
  15. #11
    fuzz1's Avatar
    Jul 2019
    Thanks just wondering how to change the vin number while keeping the file integrity. I know you can adapt it to some cars via obd port.
    Would you mind giving an example of one where you change vin number in a dump and make it pass crc check.
  16. The Following User Says Thank You to fuzz1 For This Useful Post:
    Sandeepa (31st January, 2022)
  17. #12
    Jul 2021
    new delhi, india
    I think i got wrong. The example which i gave have spc560p50lc memory chips in both. When repairing the crash, the d flash needs to be repaired for this. But when i put the d flash and the p flash files from the donor into the receiver, it has laa the data from the old part number and the old vin number. The redundant data is all gone and has new required data in it. I will pm you the old crash files and the new files for both
    Thanks buddy
  18. The Following User Says Thank You to Sandeepa For This Useful Post:
    fuzz1 (31st January, 2022)
