I now have the exact same problem as above I have tried different techniques as recommended above, the only way I can get anything is to use enforcer, but this doesnt change the error message on the screen of the DM. As soon as I try and flash it asks which file and no matter what file I use it always says "file to big". Can anyone help ppease???
Try what it says in post 21 and also different versions of dreamup there are a few
Hi thanks for your reply I have tried what it says in post 21 I have also tried load of different NFI files and still get the same message "file to big" The two network lights are constantly lit too it says on the front of the box go to dm7020.com. Also I have tried dreamup 3.1.1.2, 3.1.1.4 and 2009 by Nastas. Any other suggestions?
Have a read of the first 2 posts here and you can d/load the files to
also try dreamup 1.3.3.4 if the above don't workCode:h**p://www.digitalvortex.info/dreambox/143801-broken-dreambox-fix.html
Digital Kaos - Downloads - DreamUP 1.3.3.4
Fergal thanks for your help have now solved it, turns out I have a dodgy cable just bought another and it connected straight away now in the progress of flashing. Could you recommend an image to use that will work with sly and have cccam. Thanks again
If you have sim 201 i believe this is suppose to be a very good image
DreamEliteBH-133dv3PHOENIX sim201-SSL76c-de-dm800
Thanks again system back to normal but i am still unable to find cccam or download it, in extensions management it just goes to updating software catalogue and then doesnt go any further?
What image did you flash on as most don't have the emu addons working but the one i suggested above does.
I googled the one u suggested and used this one www.mediafire.com%2F%3F6sryd5ns9ln8txp&ei=ReuuTc2SF5D C8QOi9_zhBA&usg=AFQjCNH5qrfUdIcT-PMVffhsnJUqGUtpsg
ooops sorry try this sim201-SSL76c-de-133dv3PHOENIX-dm800-20092010.rar
Your looking in the wrong place
Press green,yellow,addons download manager,dream elite e2 image cams
Thank you so much now installed 2.21 and have got sly free channels working just messing with box key now to get the rest of the channels working on my subscription. Do I need to restart the DB when I update the boxkey?
