xprog read out B84N MC68HC11A1 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Senior Member el_futte's Avatar
    denmark
    15
    Downloads
    169
    Uploads
    y manage eather 2 read a 23c04 ... i think its a very NOT nice programmer already ordre UPA programmer .
  2. #17
    Sweden
    Downloads
    11
    Uploads
    From where did you order your UPA ?
    Think its any better ?
    Need to buy i new one too
  3. #18
    Jun 2009
    Downloads
    4
    Uploads
    Only one place for genuine UPA is
    ELRASOFT Products
  4. #19
    denmark
    15
    Downloads
    169
    Uploads
    what about adapters for hc11 and more for the upa???
  5. #20
    Sweden
    Downloads
    11
    Uploads
    I ordered a UPA-USB today, want to see if it works better then xprog-t
  6. #21
    Sweden
    Downloads
    11
    Uploads
    In the in circuit schematics for xprog-t it says XTAL pin XX;XX
    Is assume that means crystal, but should I do something with that info ? Short, lift legs ?
  7. #22
    mexanico1971's Avatar
    portugal
    1,222
    Downloads
    10
    Uploads
    hi ! anyone successful read tms 374 and 28f256 width xprog? from obd factory ! my says bootloader initializing error ! the ecu in questan is a 1ap40 mm !
  8. #23
    DK Veteran bricolo's Avatar
    france
    17
    Downloads
    11
    Uploads
    Quote Originally Posted by pinch View Post
    with UPA, to read MC68HC11A1 you must lift pins:
    Reset, MODB, RxD and not desolder MCU
  9. #24
    121
    Downloads
    10
    Uploads
    Quote Originally Posted by mexanico1971 View Post
    Hi mate, Ive got the same too with the tms 374-28f256 ECU. If you followed the programmer-ECU connection instruction in Xprog-m TMS374 manual on the page of tms 374 and 28f256 you might notice that the instruction to connect Vcc to the ECU is missing. Make sure that you have connected it to 28F256 Vcc pin (pin32). hope this help.
  10. #25
    EU
    228
    Downloads
    80
    Uploads
    Hi. I trying to read MC68HC11L6 from audi gamma cc with xprog, no sucess. My programmer says bootloader initialising error. Im not desolder MCU, can anyone help me.
    Thanks in advance.
  11. #26
    portugal
    1,222
    Downloads
    10
    Uploads
    Default problem xprog
    I'm doing a IAW 1AP40 again width xprog 4.5, all wires connect good , to read no need to connect the ac power and read it all the content, but wen make verify give bootloader ini error, if I put ac power says bootloader ini error from the start ! if I try to write give a lots of errors in buffer !
    do anyone have some situation like this ?!
    thank in advance
    Last edited by mexanico1971; 9th February, 2011 at 04:19 PM. Reason: beter explain
  12. #27
    Romania
    35
    Downloads
    Uploads
    bootloader error posible the cristal frequency seting in the xprog menu
