Thanks Mr. dijo , but it still not working
Please send me this file if you have repaired it.
Many thanks in advance.
@ ahmed9
Look in your PM
Thanks Mr. dijo
hello
i got a china clip and i have ddt 2000
does they work togheder?
thank you
There is no sense to use ddt2000 if you have and succesfully setup RENAULT CLIP.
DDT2000 is aimed for older renault cars which dont have/use CAN diagnostic protocol. It works with cheap KKL interface, and cars database is outdated and incomplete.
Renault CLIP, latest versions of original device and of course chinese copies/clones are aimed for newer cars with CAN DIAGNOSTIC. And of course there is embeded suport for older cars without CAN: ex.: Laguna I and Laguna ph2. Clio, Megane, with "old style" 12 pins DLC.
So, if you have CLIP, you already have functionality of DDT2000 inside of CLIP.
Regards, and respect
Here it is:
http://rapidshare.com/files/426177821/LT12134fa.pdf
http://rapidshare.com/files/426177837/1.jpg
http://rapidshare.com/files/426177842/PCA82C250.pdf
http://rapidshare.com/files/426177844/LT1766fc.pdf
http://rapidshare.com/files/426177848/2.jpg
http://rapidshare.com/files/426177749/lm311.pdf
http://rapidshare.com/files/426177854/SJA1000_3.pdf
RadovanPetkovic (11th August, 2020)
I see, (and understand fully, because it's same here in my country, a lot of old cars, with average age of cars in use about 10/12 years) .
And you are right, DDT2000 is somewhat less demanding and therfore a little bit more responsive than CLIP software.
I think that both of those devices are about equally slow (which is result of Kline protocols used for diagnostic of older Renault Cars) in everyday use.
And both of those softwares can coexist on same PC. I have personally this situation briefly, when I acquire my first CLIP device. You can't setup DDT software to work with CLIP interface nor viceversa.
ITS POSSIBLE INSTALL RENAULT CLIP WITH OTHER SOFTWARE (VAS PC LEXIA PPS ELSA TIS BMW ETC)?NO PROBLEM!? THANK YOU
If you mean: Can I use CLIP device with other software ex. Lexia, PPS, VAS, answer is NO. You can not. Other software simply can not detect CLIP device. Its dedicated to CLIP sotware.
On the other hand you can't also use CLIP sowtvare with other devices, because as I already said, its software dedicated to CLIP device!
Thats of course my expireience and opinion, if other DK members have different opinion, please share it with us!
Regards, and respect!
Anybody knows why I can connect to can based cars but not K-line??? Tried entering VIN manually and other soft versions?... Thanks in advance
Please take a closer look from the beginning of the thread!
You'll find answer there, ...
but, if you want to hear my opinion, then I think that you have malfunction CLIP device, ISO part of it is not functioning properly, and need to be repaired. It doesnt matter if you have both green LEDs for ISO and CAN illuminated, that is not a prof of fully functional CLIP device.
hi.i have bought clip china,someone can tell me correct way,version for install, and link for download ? sorry so many question.thankyou
M8, look here...
