Page 17 of 45 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 674
  1. #241
    Hi all i have the same problem with my firmware which don't want to upgrade. I have tried the solution to rename some file and i have found the problem it's the file APLIISO in this directory C:\CLIP\DATA\APPLI\PARAMS\. But i have let others file APLIISO.S19 in C:\ASDE\MODULES\ and APLIICAN.S19 in C:\CLIP\DATA\APPLI\PARAMS\ and it start.
    How i can fix the problem ? is it a hardware problem ? because i can't use ISO function and there are many fonctions with the iso..
    Thanks for all
    ps : All Led are on, and all drivers are correctly installed.
  2. #242
    Junior Member bo0st's Avatar
    Default CLIP v55 link
    Hi all
    Im late...sorry
    here is link for CLIP v55 install...please reupload to rapidshare. dont kill my server
    http://www.fastestracing.com/Clip V55.zip
    Thanks ladies
  3. #243
    Thank you very much ! and one more thanks for our account
    i'm uploading it to Mega, i hope that will help your server
  4. #244
    Default hy
    is sameone from bucharest hwo have problem with iso board
    maybe we try to mix them to see if the board is the problem
  5. #245
    Mar 2009
    eyxaristo
  6. #246
    Default hy
    bay sameone clip in lately
    do you have problem with it
    or just me i have a bad luck
  8. #248
    Thank you very interesting !
  9. #249
    Thanks to all for your advice, these solve my problem !
  10. #250
    Member alejuz's Avatar
    Apr 2011
    Default Can Clip Clone Renault master 2.5 dci edc15c3
    Hello friends. I have a Renault master 2.5 dci edc15c3 bosch 0281011254
    I can enter all the ecu wich Can Clip Clone (china) but not to that of calculator engine.
    I have tried with several versions V99 V104 V106 without success.
    Someone can help me!!!!
    THANKS!!!!
  11. #251
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by ziko View Post
    I found no vcc 3.3v to AN2135SC fromvoltage regulator. Actually there is no +5v IN from usb port to oltage regulator . Need +5v on both pins (1 and 3)
    Anyone have opened clip pcb to check where from need to receive this regulator IN voltage?
    On red arrow no +5V on image,normally no 3v3 to blue arrow,but on green there is +5v
    Also from back side near usb connis also same vol.reg and its have all voltages ok
    wbr
    could you please share with us the name of the volateg regulator?
    atb
  12. #252
    Jan 2009
    Please see my previos post, its smd sot23, L04 was label on it I think
  13. #253
    Land of Choice!
    Quote Originally Posted by lubeer View Post
    Did not work "ISO".
    Now the my clip works.
    Tnx Ziko and rtvservis and ALL.
    I changed the LDO but still ISO does not work.
    What should I do next?
    All the best!
  14. #254
    miha99's Avatar
    EU
    This sot23 is controled by motorola mcu and problem is in most cases in mcu (no conditions to open L04), so only solution is send back to china.
  15. #255
    hello
    I have a problem with my clipe when connected to a computer can not detect USB device hub only and does not recognize the device can anyone help
