Page 2 of 39 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 674
Hybrid View
    Top Poster baner's Avatar
    Quote Originally Posted by Claudiu_dar View Post
    Hey,
    I recieved a sonda and I supply 5v ic AN2135SC and now it asked for the CAN driver thing that never wanted before.Now is complet installed but can't make firmaware update it's stops at 20%.Does anyone know what supplys that IC?
    Thanks in advance
    Sorry for late reply. I have a similar problem with my CLIP clone.
    Did you replaced Cypress chip, or you replaced some other component of PCB?
    DK Veteran snecii's Avatar
    good info THX
    dijo's Avatar
    Hi guys,
    I need to buy one Clip interface, now every one witch the difference between this two versions...
    1? choice:Renault CAN Clip Diagnostic Interface V92-Professional Diagnostic Tools-Products-UUCTECH
    2? ChoiceRenault Can Clip 2009,price 650USD 13 from as supplier, buyer, exporter, importer, wholesaler
    A friend of my told me that one was made in France another in china, with different chips...
    Now you something?
    Thanks in advance...
    hi all! i tried to install v94 clip softfirst time i tried to install drivers - all 4 drivers was found, and then 2 devices appeared in device manager JCAE CAN and JCAE ISO and 2 red and 2 green led was active but clip software didnt recognize probe - vin window didnt appear.
    then i tried to install v97, and when i connected to the car (Scenic 2004) only can drivers was installed and green can led turned on, and iso green led was inactive. only red.
    could it be that v97 updated firmware of my probe?
    or may be interface is faulty and need to be rpaired or replaced?
    Newbie maxymax's Avatar
    Hi to all
    Can anybody help me with this issue
    Instal reg Crack first after
    I instal the software V99 (Thank you patrian)
    The system restart
    i plug the can probe in the car (ignition turn on but NOT Engine running)
    The red led from can clip are open
    Windows start to instal cypress driver. i finish to instal this and start to instal the 4 driver for can clip :
    JCAE ISO AVANT RENUMERATION
    JCAE ISO APRES RENUMERATION
    The green led is open
    In this moment windows stop to instal the rest of the drivers meens
    JCAE CAN AVANT RENUMERATION
    JCAE CAN APRES RENUMERATION
    The green led from can is close an can clip recognize the probe but can not comunicate with can probe
    Of course the can probe is chinese. Thank you verry much in advance
    guys, could someone tell me if clip software should recognize probe with only CAN green led?or it needs both CAN and ISO green leds to be on?
    the recognize is only with can led green but to comunicate must be both i think
    Quote Originally Posted by maxymax View Post
    clip software even dont show me vin window, because the list of sensors are empty.
    DK Veteran BeianM's Avatar
    Dorset UK
    Default clip no probe
    Quote Originally Posted by gest View Post
    You have a bad connection to the probe. Make good the connection of the probe to the clip. If disconnect & reconnect does not work the open clip & check solder joints of connector to pcb.
    nice work!
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Arrow CanClip error
    Hello DK?s
    I need your Help.
    I have the same problem...
    when i start can clip is want update the firmwar
    have solution ??
    i try with V96,V103,V107...all the same update frmwar and stop 20 % error !!!
    bricolo's Avatar
    france
    Quote Originally Posted by fifas2010 View Post
    Hello DK?s
    I need your Help.
    have solution ??
    try this: connect clip to car, turn ignition on
    then connect usb clip to PC then run clip soft
    works like this for me vith V106 and clone clip
    I learn every day and I share my knowledge
  13. #13
    Jun 2013
    morocco
    nice job man
  14. #14
    Hello
    my Can clip not work iso light not on or binking
    and 2 transistor or mosfet missing instead of diode! 2 normally diode solder by factory
    which one mosfet or transistor 2 missing???
    regards
  15. #15
    titoun's Avatar
    Dec 2010
    Try to change 32.768 KHz quartz on ISO Board ! Here:
  16. The Following 2 Users Say Thank You to titoun For This Useful Post:
    AndreiBBF (31st October, 2016), PierreTheron (8th April, 2016)
