Page 39 of 45 FirstFirst ... 293435363738394041424344 ... LastLast
Results 571 to 585 of 674
  1. #571
    Jun 2012
    Quote Originally Posted by pulsar2000 View Post
    Anyone able to repair my clip if i send to them , ? no comms from usb, no leds, dead unit, worked fine then no usb comms, its a china clone, cheaper to send E.u repair, anyone ? willing to pay,,,,
    anyone ? if no sending back, willing to pay for a fix,,,
  2. #572
    maaxxyy's Avatar
    North Pole
    Hi guys i have an issue with my clip. Booster pack on car fried my clip so i replaced the 2 quartz and 2 AN2135 on both boards. Now i have firmware update (renamed files in directory) and all leds light up on clip. I can read the vin number from a 2013 traffic but cant detect any ecu on network test. Any help would be great. Thanks
  3. The Following User Says Thank You to maaxxyy For This Useful Post:
    Med01 (26th December, 2015)
  4. #573
    morfej's Avatar
    Check CAN SJA1000 chip and relay next to it.
  5. The Following 2 Users Say Thank You to morfej For This Useful Post:
    maaxxyy (12th January, 2015), titoun (10th February, 2016)
  6. #574
    thinks to all
    not work with my clip
    update err
    plz help me
    best regards
  7. #575
    Dec 2015
    I have renault can clip V153
    and when i using it to make a test for my car it's suddenly disconnected
    and then it's begin to work again then disconnect and so on.
    so what can I do. in this case
  8. #576
    Newbie Med01's Avatar
    Dec 2015
    Hello Pro Friends
    I would like to buy a clone Clip
    Any one advice me which one i should buy
    I heared that there is Clips with RLT 2002 and others with alliance drivers Boch
    Please need advices and how i can know the right one
    Envoy? de mon SM-N9005 en utilisant Tapatalk
  9. #577
    Dec 2015
    Hello friends
  10. #578
    Dec 2015
    Quote Originally Posted by vicman32 View Post
    hello,
    I'm a new clip alliance VI clone.
    Green LED flashes and the pc ISO does not recognize the clip.
    anyone know it can be. I not find de oscillator.
    thanks,
    regards.
    Hi friend
    I want to know how i can know the Clip alliance from other Clips
    Is it more beter than other Clips
  11. #579
    thanks to all for sharing
    my clip not work plz help me
    best regards
  12. #580
    Dec 2015
    I have a Clone Clip too.
    My Problem is , a newer Megane III with Multiplex Can works fine.
    But older Twingo dont.
    And when i take not Renault --> Scantool ISO 9141-2 and ISO 14230-4 it didnt work.
    In my Computer there is only one Bosch Automotive Service Solution Device --> 1B-Alliance Vehicule Communication Interface
  13. #581
    Quote Originally Posted by peko View Post
    hi friends
    thanks for your help, but nothing change, strange is : with cars all ok, but lot of anothers lose communication always
    other solution ?
    exactly the same behavior have mine too.
    do you find the cure for that?
    br.
  14. #582
    Jan 2016
    Minsk, Belarus
    Quote Originally Posted by amir_82013 View Post
    I install version 131 clip good but after a few days for opening software give me Error 15024 and 15028
    What is problem ?
    i check Interfaces = Good .
    LED Interfaces = Good (Green and Red) .
    Cable: USB & Prob = Good.
    install again software = but not solved problem.
    Please help me. it now can't connect to car.
    Thanks.
    I have the same problem. Did you decide this?
  15. #583
    Feb 2016
    I'm french, sorry for my english...
    I have a not bad clone can clip V127 with AN2135sc (with 2 green leds on) (automatic VIN is ok ). But it's not possible to update to actual firmware to V154. block to 74% (and 20% on other old clip version V132 for example).
    I would like to know if its a problem on pcb can or iso. when can clip receive a new firmware, what is happening on pcb. Is it 2 firmwares ? one on ISO pcb and 1 on CAN pcb ?
    is it possible to load firmware manually ?
    any information are welcome
    Yann
  16. #584
    Nov 2015
    Hi guys, I've read this entire topic and I will try some things (mainly the oscillators), but still have a doubt related to my Renault Can Clone. The ISO green led isn't on. What could be the main reason for that ?
  17. #585
    Hello
    my Can clip not work iso light not on or binking
    and 2 transistor or mosfet missing instead of diode! 2 normally diode solder by factory
    which one mosfet or transistor 2 missing???
    regards
