AndreiBBF (31st October, 2016), PierreTheron (8th April, 2016)
I have a problem with the probe CAN CLIP (PCB version, such as the photo attached). The problem is that the software update probe stops at 74% and goes no further.
Drivers are correctly installed, the program just tested versions of the V151 and V153 on a variety of laptops (before work)
After connecting the power and USB light up all the LEDs 2x 2x red then green.
After renaming the file "applcan.s19" passes away and connects to the cars after KLINE (eg. Laguna I ph1). I know it does not solve the problem but I think there is a fault on the PCB CAN \ USB?
I bought CLIP (china clone) a few days ago before the error was merged with two cars Espace IV and Laguna And after that came the above described error. Installation in these cars is OK because other diag interfaces works
Please, any tips guiding me to the cause of the problem. Flash memory on board CAN is broken for some reason? Could this indicate a problem with the software?
Changing the software (on PC) version of the V151 to V153 could cause such a problem?
The connection with internet WiFi run time with Clip software may damage something, or is it just a myth?
Sorry for my English. I use translator.
Thanks for this topic.
I just received my CAN Clip from China (Gold PCB version with AN2135SC/36).
The problem is that I have a non blocking error while testing multiplex network : Short to earth on CAN Low
The software (V153, via VMWare on my macbook) says it's non blocking but it could generate false diag.
The fact is, I can seem to access to my ECUs but I don't know if everything is really available. It seems to work on my Laguna and Scenic but shows the same multiplexer fault on 2 cars (short on CAN L).
Could this be a software related problem or is it a hardware fault ?
thanks thanks
hi, i have problem canclip, lose conexion with car , same with all modules, i conected and disconected all moment same , any have any solution for this problem.
thanks in advance.
ECM TITANIUM ORIGINAL KTAG MASTER ORIGINAL
And what is broken in my case? 4 drivers found, firmware updated ok, but cant connect car at all.
I bought a Renault CLIP Can, it's detect all drivers but can only turn on 3 lights (don't remember if it is CAN or ISO). I've already swap the 32768 khz oscillator, but still no luck. I've notice that the PCB have some differences between the images that were post here. What can I do next ?
I have 3pcs Can clip with 74% error. Change iso flash, can flash, iso AN2135SC, can AN2135SC, iso eeprom, can eeprom, can oscillator, iso oscilator, usb cable. All parts reflow. 2 red led and 2 green led light, and after start make only 74% in status bar. Software V143 nad V156. System Win XP, Win7 32bit Profi.
Any idea?
Any update?
Hi. I have exactly the same problem...I bypassed an update by renaming these two *.s19 files and the Clip is starting but could not recognize VIN. After entering VIN manualy error is coming up when connecting to multiplex network
I have the same problem with sensor error. Is the oscillator a common problem?
I saw a post from obd2express.co.uk,about how to solve CAN Clip v159 RLT 2002 Probe ?Failure of reservation of probe?,i think it's useful.
here's post said"Here are optional user solutions for the Renault can clip v159was connected to PC, detected with the number 926 573 and recognized " RLT2002 PROBE?, but CLIP popped an error message- "Failure of the reservation of the probe. Try it again and contact technical assistance in case of another failure? .
--> First, you can try the easy solution:
check in device manager, it is alliance B
yes works with both but not work on both on same partition so better to install on different computers or use the boot it.
best to install Clip first and let that update the firmware and then install Consult 3 scan tool and enter serial you saw in Clip software , as above.
I have made it many many times .
--> Still not work??
That is....
You don't have a real CAN CLIP RLT2002 PROBE
You have a hybrid of Alliance VI in CAN CLIP case
It will work good don't bougter of it
It will install only one driver instead of 4 as for real CAN CLIP Probe
And much more of this it is working wit Consult III software till 9.21.02 as well
You can check and see the difference between this two kind of Chinese clones:
real CAN CLIP PROBE clone - RLT2002
Allianbce hybrid Can Clip sonde - 926573
Today I install program and I plugged clip and I not disabled the Internet . Now I have a problem with that with stops at 74% and does not work. I have a second clip and this is updated but does not recognize the VIN . Someone can give me a hint what could damage? before the first clip worked fine .
Hello. I have a RLT2002Probe, if I connect to the car and USB only appears two new devices. This is the ISO after re-enumeration and CAN after re-enumeration. Two more are missing. And fails to update the internal program hangs at 74%, however, if I rename the file applican.S19 upgrade takes place and the program starts. Оscillator on the PCB CAN I replaced.
What could be the problem?
Thanks for help...
