Page 4 of 45 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 674
  1. #46
    Member aitistu's Avatar
    Timisoara, Romania
    Quote Originally Posted by nono2lozere View Post
    hello,
    you have the old interface, i have this too. You need clip V74 because this is the last version whitch work with diaghub and diagcom. search in automotive software section, hope it will help you!
    good luck!
    i have version 6.1 or 6.7 (original cd), it was the version installed on broken laptop. i tried with newer versions from this forum also
    any other info apreciated
    c
  2. #47
    hello,
    go here: http://www.digital-kaos.co.uk/forums...-v-74-a-55545/ and download it !
    good luck!
  3. #48
    Timisoara, Romania
    hello,
    good luck!
    thanks very much, i installed, and tomorrow i will try to see if works
  4. #49
    DK Veteran snecii's Avatar
    good info THX
  5. #50
    dijo's Avatar
    Hi guys,
    I need to buy one Clip interface, now every one witch the difference between this two versions...
    1? choice:Renault CAN Clip Diagnostic Interface V92-Professional Diagnostic Tools-Products-UUCTECH
    2? ChoiceRenault Can Clip 2009,price 650USD 13 from as supplier, buyer, exporter, importer, wholesaler
    A friend of my told me that one was made in France another in china, with different chips...
    Now you something?
    Thanks in advance...
  6. #51
    DK Veteran BeianM's Avatar
    Dorset UK
    It appears that they are both Chinese companies. So both will be clones. I don't think these are made by the original manufacturer any more. If you are going to buy a clone then check out Alibaba.com Wholesale Platform - Get wholesale products from China wholesalers! you can search many china companies. It has a feedback rating similar to ebay. Also the supplier does not get paid until the goods are delivered. If the goods are not shipped within 5 days the order is cancelled & your credit card is refunded automatically, no need to contact the supplier.
    Also check out ebay of course. But first check the advice in the thread on buying from china.
    $600 is a lot of money for a clone, You could get this in the UK for around ?300 or less.
  7. #52
    Timisoara, Romania
    Quote Originally Posted by aitistu View Post
    it doesnt work, same story, clip says :check intrface cables ....
    in dev manager only diaghub and diagsomething are listed
  8. #53
    yes it s sure
  9. #54
    dijo's Avatar
    Quote Originally Posted by BeianM View Post
    Thanks for your post BrianM! I post the two links only because there are two different IF, but i think the difference is only in the black plastic cover in one, and the other is simply without the plastic protection and the IF are exactly the same...
    Is it not throw that exist two different chip?s inside the IF from two different manufacturers...?
  10. #55
    have you try to enter VIN manually, because I had to do that with an espace III. I don't know why but scantool (generic OBDII) doesn't work with it, only "normal" scan.
    Does the green light blink when you try to communicate with car ? I also have problems because interface wasn't reconised by windows and the light keep red on diagcom.
    hope it could help, good luck!
  11. #56
    Dorset UK
    Quote Originally Posted by dijo View Post
    I dont think you can go by what you see in the photos. I doubt they have taken their own but copied from another website. With the china clones I think it is pot luck. I am sure they are made by peasants in their sheds at home. Get it from a good source & if it doesn't work then you send it back. From what I read above it looks like some suffer with poor quality chip sets or they are damaged in manufacture. I can't imagine they test them before sending them out.
  12. #57
    Timisoara, Romania
    i didnt try with vin manualy, i dont have any leds on the interface, its the bottom part of a case which also contains the laptop (i'll make some pictures) ;your help is very apreciated.
    i have kinda give up the ideea of a functional clip, today i tried to code injectors on 1,5 dci renault engine (on dacia logan) with ddt 2000 but it's saing "normalized injector code request missing in ecm database" (in ddt2000 light) I sure i'm missing something , i had only half an hour to play with ddt2000. Is there any manual for using ddt (especialy coding injectors, because the rest , read failures, erase, live data is working like a charm)
    thanks again, great people, great forum
  13. #58
    Timisoara, Romania
    success at last:
    the ecu was dcm 12 l4c71 and i was usig autodetect, and autodetect selected first ecu file (dcm12 - l4c71 - v6.0) that matched, a file which doesnt have the injector code part.. manually selected dcm12 - l4c71 - v6.2 (a newer version for same ecu) and the injector reprograming screen apeared as normal
    c
  14. #59
    i need cypress CY7C65113C ic hex file
    could you help me please...
  15. #60
    Timisoara, Romania
    Default mono motronic ma 1.7
    hi
    does anyone know what protocol bosch mono motronic 1.7 use?
