Thank you for sugestion, I know that, you are right. It wasn't that to me... when I moving cable, red USB light flickering and loose connection... broken cable in connector type A. As I said, replacing cable problem solved.
[quote=BeianM;600462]You have a bad connection to the probe. Make good the connection of the probe to the clip. If disconnect & reconnect does not work the open clip & check solder joints of connector to pcb.[/quote]
At my work but I have every time disconnect & connect.Its the problem is in blue usb cable or multiplexer,and I keep getting this message.
Hy guys, I need the wiring diagram for the Clip Sonde...
If everyone have it, please share it... it was very helpful!
Thanks a lot in advance!
its good to see there is allways an alternative to complete replacenent, excellent
Hi Guys,
my problem with Clip clone is different, namely all drivers install themselves correctly, lights ISO, CAn etc. work fine, probe recognises VIN, then I switch to main menu where I can choose controllers to be diagnosed, and then problem starts...
sometimes probe can connects with the controller ( anyone, for. ex ECU ) but after a seconds program automatically turns me back to main menu, or sometimes probe cant connect with controller at all.
Oginally I got software V96, but I try to use it on V100.
Any ideas what can be the problem with?
Thx.
v100 has some problem issues with cloned clip.Try v 102 ...
ok I will check it as You advise, Thank You!
I have the same problem with mine, bought from columbia dream on eaby .I have updated from v96 to v99 but it still does exactly the same.I will be watching the threads closely to see if someone has an answer to this problem as i no longer have the time or the inc lination to persevere with it .
I have too a problem with my clone CLIP probe ...
I have CAN geen led on but ISO green led off !!!
and my Probe isn't visible on CLIP SOFWARE ...
I precise to you that I used it succesfully last month on my MEGANE DCI 2005 ...
HUB CYPRESS and JCAR avant/apres renumeration driver is load but My proble isn't visible in V96 (or V98 on anower notbook)
It's my CYPRESS Chip it's fault ?
but when I open my probe I have found 2 AN2135SC Chip one per board ?
witch it HS ?
Thanks for Your answers
Best regard Alain
HELLO TO ALL.
1: I can clip clone is not detected by my computer, the green light of the Protocol can not work
2: I've changed AN2135SC. NO PROBLEM SOLVING
A: What should I do
1: change an2135sc second time
2: probe can clip clone in the trash
3: I mow luck with probe clone longer works
DK, I NEED HELP TO FIND SOLUTION TO THE PROBLEM (PROB 2002)
thank you in advance
