one way to solme MY problem with "reserving" clip was,after ome week of troubles,this: in one car-clio 2006,when i start clip,appear error on sonde,repluged and still error,i put the clip without taken the usb cable on a Laguna 2000 and the program starts ok,after that i tryed again on clio,it worked fine,so now,after 3 more cars and the same problem,when my clip refuse to start,i plug the usb cable and the obd cable to a blank obd2 connector with only the plus and minus wires,and the clip starts EVERY time. What can be the answer?
and now,after that,i did not shut down the laptop any more, i unplug the usb cable and when i must use clip,i plug it and works every time...
...maybe it will help you too....
