Results 1 to 5 of 5
    Default injector help please
    hi i have a 307 2.0l hdi, (110) rhs in vin, can any one find out the part numbers for injectors,as 2 of mine are running low and causing poor idle and a rattle,or whats the best stuff or way to clean them??? any help would be greatfull for p.s they bosch.and have acess to pp2000
    thanks guys
    Ashraf6119's Avatar
    Nov 2009
    UK
    Call your local Dealer they should be able to give you the Part Number.
    Hope This Helps
    Ash
    Newbie boulderbros's Avatar
    Feb 2010
    Default Injector Supplier
    Have you tried
    WORLDPAC - The Right Part at the Right Time
    They have an extensive inventory
    Newbie thehuhu's Avatar
    Jan 2010
    Serveur prot?g?
    make a free account and start browsing for part, type your VIN and search
    Nov 2009
    Bosch common rail injectors can be repaired with a bad idle it is probably the nozzle. If it,s hard starting it could be too much back leakage from the injector the seal has gone.
