Results 1 to 10 of 10
    Default Engine Diesel - help
    Hello people !!!!!
    Which program is many good for works with Engine diesel common Rail system ?
    scanmaster-ELM 2.0
    Digimoto V5
    Proscan 5.5
    My Pik-up is an Nissan 2.8 TDI , year 2007.
    Thanks for the reply.
    DK Veteran sl4ck's Avatar
    Please specify better what do you whant to do.
    Read/Erase DTC's ?
    Install new ECU ?
    Read Sensors?
    Sensors check?
    None of them. You should use the dealer tool if you want to be able to see live data and trouble codes.
    Quote Originally Posted by sl4ck View Post
    Read/Erase DTC's ?
    Install new ECU ?
    Read Sensors?
    Sensors check?
    Yes , read sensors and erase falty codes .
    Thanks.
    Quote Originally Posted by oldford View Post
    Yes , but the protocol is 9141-2 !!!!!!
    So, it's 9141-2. And what is the advantage of that?
    It is Standard Protocol .
    I think ScanmasterELM with ELM327 or compatible should be enought to Read/erase DTC's
    For reading sensor values you would need the new Scanmaster V2.0, but reports on this forum say it's full of bugs. So, you're stuck with V1.9, but that one will not show any live data for the particle filter or variable turbo. If you have problems with those parts you still need the factory tool or equivalent.
    May 2011
    Scanmaster 2.1 is supposed to be a good version.
