Results 1 to 5 of 5
    Oct 2020
    Default MB Vito W447 eeprom 25640 / 95640 need check new eeprom with new milage
    Hello is it possible that someone will calculate new eeprom from my oryginal? The new with 28236km.
    I have DUMP tool but I have some problems after I am writing modified eeprom and would like to check is it problem with my DUMP tool (SMOK) or not.
    Generally I read the memory with no problem (read as 25640 or 95640 - the same files).
    I changed the milage with dump tool (from SMOK). Checked the new file and is corrected changed the milage.
    Write the new file to eeprom, double checked and veryfying and is new milage.
    I connected dashboard to the car and car shows 0 (zero) km.
    I write the oryginal milage eeprom and shows ok 48236 km.
    So why the dashboard read 0 km from eeprom which has new milage corrected writed?
    This is why I would like to check if another DUMP tool calculate new eeprom wnd write and check.
    p.s. I also tried with anothers eeprom wrom another w447 but always see "------" on dashboard.
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by viper111 View Post
    what about blocker ?
    Oct 2020
    Yea I disconnect can blocker and the same situation
    Aug 2016
    EURO-KOLCHOZ
    what blocker do you use?
    Oct 2020
    Quote Originally Posted by jetronic30 View Post
    I use CAN blocker like on picture, but as I mention I removed can blocker and still the same problem, zero (0) on dashboard with eeprom with new milage.
