Results 1 to 4 of 4
    May 2014
    Default Audi Q7 Steering Lock replacement
    Hello ,
    2007 audi Q7 steering lock which serves as the immobilizer with eeprom 9S12 went dead .
    i got one from the market with its key and key cylinder . now i have pin codes for both
    steering locks and i need procedure how to code it .
    a forum member helped me made immo off of the ecu and car started
    But on the cluster displays SAFE and nothing is working after the car started .
    i using Maxisys Elite and Abrites original
    can anyone help me procedure how to solve this issue ,
    Thanks very much
    Jun 2014
    hi, procedure of ezl of your car can't done by pin. abrites need original old ezs eeprom to continue the adapt procedure. in your case you need odis online. and to accept by odis online the programming,so you must need to virginize your ezs dumps, and then by original old key can adapt the ezs + C-P .
  3. The Following User Says Thank You to pouleddy For This Useful Post:
    INFINITY13 (20th December, 2021)
    May 2014
    Can i just swap or put the old eeprom dump onto the new esl and use the old keys ?
    will that work ?
    Jun 2014
    hi, 1) if your eeprom + flash of original old ezl are ok? so by programmer write those both files in donor ezl, 2) if you can read old original esl eeprom and it was OK the eeprom, so you can by obd2 use abrites by loading original eeprom in and adapt by original remote keys, after you can do by obd2 the components production to work your dash.
