need to have fiat can commander
you must connect +5V VCC and 68HC11F1 pin 34
see picture
and must connect ECU +12V and GND
ha ha ha..ok I gues this is yoke on my account ? of course it is conected on 12 and gnd...and red wire on photo is power suply for this 232 interface..5 v is internaly suplayed to F1..I cheked few times all this still no luck..actualy 2 pins of ECU is power suply with 12 V and 2 is ground(not sure right now but...) I am sure some driver mising..but have no luck to find wich one
anyone know where I can find a guide to delete the ZIP code Fiat IAW 59F.M2 (Hybrid)
a moment ago I cleaned the ecu 8f.5t
xprog on the left
this is old xprog..not M ? I have it too..works fantastic on old garage Pc,but after some upgrade in garage old xprog cant work with xp..so I dont have solutions for IAW..I will order upa usb so I hope all will be fine
regards!
OK so today I upgrade xp on service pack 3..check interface for 'fiat eleiminator' change max232 from another manufacturer(now maxim) start sw. and voila all work fine..so for any of you who will try keep atention to maxim IC tested on few Pc work on every xp..
IF initialization failed at first try ..REMOVE power from ECU then try again....
landrovertdi Thank you for this sw..
Sorry friends...IAW 8F.5T have HC11A1 with 52pin...no HC11F1 with68pin this ecu is without i*mo...line i*mo the conector is pin7...this pin is without cable....no i*mo box....no i*mmo.
I need interface circuit ECU to PC Please.
Hi! Can I have imm*o off for this Alfa R. 145 ?
ECU IAW 8F.6B MCU HC11F1
Thanks!
the files are missing.anyone has them?
