i installed on win 7 32 bit works great .... i tried on win 10 64 bit after loading the software crashes .... i think same problem you have to stop your antivirus software ....it will work (install in C drive )
Hi friends I am fighting with autocom 2020. I can not install it. I have done a new win7 installation 32 bit and when I try to install it I have mini black screen and saying program to big to fit in memory..then I tried to install it on win10 whick I have odis and ksuite and then I have message that exe is corrupted. When I tried to run it like admin I have message that can not find path from exe. What I must do please someone an idea? Maybe I must install win7 64bit? I have 4 gb memory on my laptop
kospoz (28th December, 2021)
Disable the built-in Windows Defender. Run the exe file as Administrator. Internet must be Turned on During Installation. VC ++ 2010 will be downloaded and SQL Compact
kospoz (29th December, 2021), LuckkyLuke (28th October, 2023)
Autocom 2020.23 installs single framework, visual and tester drivers
you should redownload from elsewhere that is your issue
If i Helped you,use thanks and rep button to thank me back
Prichyndel (30th April, 2022)
