Unplug TVA
Unplug TVA
mm04kk (29th December, 2021)
Now i have error 2529 and Mil is on and car no power
Here, should be fine...
Unplug the TVA!
now no dtcs mill is off but car dont have full power
Your file pass in PM
Unplug TVA
File Service - contact PM
"Naród wspaniały, tylko ludzie ku*wy" - Józef Piłsudski
There is no deleted error codes in my file, just diagnosis of the TVA is turned off.
So, if you don't have any DTCs about TVA on diag, and you disconnected it - my job is done as should.
Now is time to find why don't have full power - in my opinion the boost is low.
Check on the road about MAF and boost...
Regards!
sepistar (29th December, 2021)
yes the boost is low turbocharger already changed egr too and with xentry the turboaktuator is working . but when i accelerate car on road the aktuator dont go up and down . I will change the tva and look what happens bacause tva was the only fault that was in diagnostik. Thank you all for your help
The actuator is no go, because the boost is low and the error code for underboost condition is deleted in your swiftec file.
The EGR, which you said is changed... almost all errors are deleted, but it is working, which is not right in any case...
The error about the SWIRL is deleted too, but who knows in what condition are the flaps now...
So, go ahead with changing the TVA - it is must to have, because is the only thing, which will prevent the engine from damage when the turbo blows. But i think this will not solve your problem.
The conclusion is, that you have to repair some shit, without knowing what was done before... and i can say, that what was done - wasn't done right.
Regards!
mm04kk (16th January, 2022)
