It comes out that it's 192760 now ,can someone check if there is so much and if the value on 168811 will be: 29 36 ?
Your dump is bad. Looks like you removed some data and posted file.
But KM in your posted dump was 192,742km.
For 168,811km
first two lines in eeprom.29 37 29 37 29 37 29 37 29 37 29 37 29 37 29 37 29 37 29 37 29 37 29 36 29 36 29 36 29 36 29 36
AchtungPress the magic button
Hello, I thought so too, and in the file xxxxx I wrote it myself, if that's it, I will check and let you know, I can know with what software you calculate it? Of course, thank you and click Thanks
I had to lengthen your file with FF’s to be able to use it in calc. It’s too short. I used VVDI2, but there are other softwares that don’t require hardware to calculate. I think if you ask nicely, some user on this forum could sell you calculator and scripts.
I don’t know your level of experience but you will have to read dump again before editing incremental zone.
Well, I am shocked, I thought that it reads 100% whole, I read desoldered, I have no way to clear this memory, so I will buy a second one, do it in two lines FF FF, and then enter 29 37 can work, I will write how it went
I found a similar file and pieces are actually missing
What tool are you using? What car is it? Year? If long ID is lost then bad news. I can make a new dump for you but send the original and dont remove anything from it.
the programmer is revelprog, the password I sent the message, thank you for help
Hello, the programmer r 270 and 160d0wt solved the problem, thank you Alawigmx
