Results 1 to 5 of 5
    al70's Avatar
    Nov 2017
    Éire
    Default Carprog device locked
    Hi all, I bought this carprog a couple of years ago, it always worked fine, this unit came with a built-in server emulator for online work, however I can't find the guy on the bay that I bought it from, maybe someone recognises the pcb , this unit worked without any rework to the pcb, this is the software that came with it, what are my options now ? Cheers all
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    carprog have as say 500 credits.....
    if you use it for those times, a i think is normal that the tool locks...
    re flash the mcu and should work fine for 500 times more....
    check at your left down screen to see the device sn.......
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    al70 (9th January, 2022)
    al70's Avatar
    Nov 2017
    Éire
    hi panathaole, this is the lib file that came with the unit
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by al70 View Post
    you must reflash the mcu......
    is not very difficult..... (first time maybe is....)
    you have to read....
    google carprog re flash..... check here for start too.... https://www.digital-kaos.co.uk/forum...h-Step-by-step
  6. The Following User Says Thank You to Panathaole For This Useful Post:
    Dec 2017
    https://www.digital-kaos.co.uk/forum...t=carprog+8.21
  8. The Following User Says Thank You to santi03 For This Useful Post:
    al70 (10th January, 2022)
