Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 107
  1. #31
    Ok finally got a chance to desolder the lcd successfully.Gonna try and read out the 93c56 chip on the board.Can someone tell me if there is any differences between 93c56 and a L56R chip???I have one speedo with a 93c56 and one with L56R.also I still have some solder left over inside the holes on the pcb which are very small.Anyway to removed the soldering from inside the joints??
  2. #32
    Quote Originally Posted by AudiS4 View Post
    93c56 and L56R is the same.
  3. #33
    DK Veteran martiboy's Avatar
    Nov 2008
    bonny scotland
    To remove the solder you can use a suction pump or sometimes i heat it up and blow through the holes.
  4. #34
    thanks for your inputs.I will try and post results.As mentioned earlier alot of you suggested to desolder the chip in order to get a valid and good dump.If I try to read with clip and the read fails will I still be able to desolder the chip and read it in the programmer or will I need a good dump??
  5. #35
    If you only read is not a problem, but if you than try to write...
    Before you read, short the quarz!
  6. #36
    I dont see a quarts anywhere on the board.Can anyone point it out where it is??or does my board even have one??
  7. #37
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    probably not got one so best to remove to read it
  8. #38
    Quote Originally Posted by teerak2uk View Post
    Yes, If no quartz, remove the eprom
  9. #39
    Anyone know which pins need power and ground in order for me to test lcd and make sure i have the correct mileage displayed with no errors???
  10. #40
    Nov 2008
    bonny scotland
    Here you go
    LOL its taken you 10 months to get to this stage
  11. #41
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Look at my previous posts i had already posted that info for you
  12. #42
    Yeah Small steps in progress.LOL.This has been on the backburner for a while.Between my Audi S4 and other projects,Too many to count and not enough time.
  13. #43
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    maybe try doing one job at a time
  14. #44
    Ok so again finally a little more progress.I still have the lcd desoldered.I tried putting +12v to the pins you pointed out but wasnt able to get the led on pcb to light up only the low fuel light led lit up.Im assuming I need the lcd installed to complete the circuit for all the leds on the pcb??
  15. #45
    dashradio's Avatar
    Inafield
    I think you just answered your own post there, of course the pins on the LCD need to be soldered back in to complete the circuit
